34 Users Online (32 Members):
Forums >> Revit Building >> Technical Support >> Wall-mounted Railing
17 Posts No Rating |
Hi all, I am working in RVT2010 and trying to create a wall mounted (stair dependent) railing in a firestair where the outside rails are mounted to the wall (instead of to a baluster and stringer). I cannot find a railing family (don't know where to look, perhaps) that does not include a baluster. How do I turn off the baluster or where can I find/load a railing that does not include a balluster? Thanks for your help!
Nevermind. I figured it out. For those of you having the same problem: - Go to the Element Options (having selected/highlighted your railing you created)
- Edit Type
- Hit 'EDIT' for 'Baluster Placement'
- Under the 'Baluster Family' column, selected 'NONE' for the 'Regular Baluster' row
This will solve the problem and get rid of the baluster. Hope that makes someone's life a little easier...
- Edit Type
Handrail - Wall mounted |
Fri, Apr 28, 2017 at 5:35:54 PM
handrail, wall mounted |
Fri, Feb 13, 2009 at 1:47:36 PM
single wall railing |
Thu, Feb 16, 2006 at 4:44:19 PM
wall mounted toilet wall error |
Wed, May 6, 2009 at 3:41:37 PM
Wall mounted carriage / lantern lighting |
Thu, Feb 11, 2016 at 8:25:27 AM
