Forums >> Community >> Newbies >> creating a scv file in autocad to use in revit
Tue, Oct 13, 2009 at 7:34:52 PM | creating a scv file in autocad to use in revit
cadtek66
Hello
I have created a topo drawing in autocad using polylines and then assigning an elevation to each line.
I tried exporting a csv file from this cad file but no success. Can I create a points file from this dwg or do I need survey software. Just for the experience, I want to see the difference of creating a toposurface in Revit using a points file instead of creating it using an imported dwg.
See attached dwg and let me know if this possible
Thank You
Wed, Oct 14, 2009 at 10:24:12 AM | creating a scv file in autocad to use in revit
I juse sent you a lisp program that will convert ACAD points to a CSV file but you need points - not polylines.
Hope that helps.
Creating surface topography from Autocad file
Fri, Feb 25, 2011 at 4:15:11 AM
Creating Revit Topo from AutoCAD file
Wed, Mar 7, 2018 at 8:30:50 AM
Creating a PLT file directly from Revit for sending to HP 750 plotter, how?
Mon, Sep 24, 2007 at 10:22:46 AM
exporting to autocad
Fri, Aug 31, 2012 at 7:35:41 AM
dimension change when importing AutoCad file
Thu, Oct 16, 2014 at 10:59:01 AM
Page generation time: 2.6348
