25 Users Online (23 Members):
Forums >> Revit Structure >> Technical Support >> Attaching beams to model by face roofs - limitations?
6 Posts No Rating |
Hi all Just testing the limitations of working structurally with roofs created using mass and the Model by Face method. I want to attach a steel beam to the roof. I believe that I can attach a beam using the pick line tool for the edges of a roof to match the profie of a roof, but not internally like you can an extruded roof. Are there any known work arounds to this? Can I have a beam system that attachs to the underside of a roof that has been formed by creating a mass and then a roof using the model by face tool? For a reason for why we may do this, consider the profile of a bowl stadium and the structure that supports the cantilevering roof. Any help, greatly appreciated.
6 Posts No Rating |
Should have said. I'm using Revit Structure 2010.
Without testing, how about creating and aligning a reference plane to the u/s roof and then either align the beam to the reference plane or use the reference plane as the current 'work plane' for the beam as you draw the beam ?
6 Posts No Rating |
Hi Daryl. Thanks for your reply. Yes, thats a very good idea as you can align and contrain the reference plane to the roof and align and contrain the beam to the reference plane. Unfortunetly the type of roof I have, a stadium one, is curved in two directions. I actually don't think its possible and I'm going to have to use something like Autocad Structural Detailing, but I wanted to sound you guys out first.
Installing analytical line into a in-place framing family? |
Wed, Oct 14, 2009 at 1:44:41 PM
Attaching curtain walls to multiple roofs |
Mon, Nov 5, 2012 at 2:19:44 PM
Face-Based Family for Void Form? |
Wed, May 18, 2011 at 10:19:38 AM
Same Opening Across Many Beams |
Thu, Oct 29, 2009 at 7:10:29 AM
Attaching structural columns to beams - mitered joint? |
Mon, Nov 15, 2010 at 3:37:44 PM
