Forums >> Revit Building >> Technical Support >> Wall Core Visibility
Mon, Aug 22, 2005 at 4:23:01 PM | Wall Core Visibility
JoeDrevitO
Is there any way to change the visibility of certain wall layers? For some uses I want to show only the core of my walls and for others I want the full thickness with finishing. Having to switch back and forth between two wall types, one with the finishing and one without would give me a nightmarish time with wall joins. Cheers!
Mon, Aug 22, 2005 at 4:34:26 PM | RE: Wall Core Visibility
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can use host cut overrides to set certain layers of a wall to be an invisible line type, but doesn't actually switch them off. This is also relying on you not having at cut pattern for these finish layers. Unfortunately this is the best solution at this stage.
Mon, Aug 22, 2005 at 5:57:02 PM | RE: Wall Core Visibility
JoeDrevitO
Its a good enough solution for me! Thanks Mr. Spot!!!
Thu, Oct 9, 2008 at 10:11:12 AM | Wall Core Visibility
cshively
Have there been any resolutions to modification of the visualizations to be able to show the core only without using the host cut overrides.
Thu, Oct 9, 2008 at 11:53:58 AM | Wall Core Visibility
coreed
coreed Avatar
4 Stars: 16 Votes
i don't think there has been change in the status quo. Mr. Spot's post still holds true for me.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
hiding core elements in a wall section
Fri, Jun 23, 2006 at 1:07:58 PM
wall types, core boundries + dimensions
Tue, Feb 28, 2006 at 4:29:55 AM
Roof / Wall core problem [ 1 2 ]
Mon, Jan 30, 2012 at 6:06:21 PM
16
Wall visibility Core/Finish
Tue, Jul 3, 2007 at 8:39:04 AM
Stacked Walls - how to set wall core
Mon, Apr 20, 2015 at 7:33:52 AM
Page generation time: 0.9006
