Forums >> Revit Building >> Technical Support >> Adding a furniture component to a legend
Mon, Oct 12, 2009 at 5:26:36 PM | Adding a furniture component to a legend
RNLRNL
I have created a piece of furniture using the "create in place" function under the components tab. I now want to add this piece of furniture to a legend but when I run through the list of familiies under legend components the furniture I created isn't listed. Does anyone know why this may be?
Thanks
Mon, Oct 12, 2009 at 6:36:55 PM | Adding a furniture component to a legend
emgeeo
3.5 Stars: 7 Votes
I don't think you can place a 3D object into a legend view.  You could create a view of the furniture, duplicate it many times, and place it on each sheet...
Tue, Oct 13, 2009 at 9:04:38 AM | Adding a furniture component to a legend
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Ok, I will begin by suggesting NOT using an in-place family to create furniture. Unless it is highly customized and unique only to that project.
Create the furniture item as an external family file, then load it into your project.
I've never tried to add an in-place family to a legend. Maybe it's just not possible? I would check / varify the family 'category' and see if that enables it.
Legend Component View Direction Problem
Fri, Mar 13, 2009 at 8:57:49 AM
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:33 PM
Legend Component view direction question
Wed, Jul 9, 2008 at 2:14:42 PM
cannot place generic model onto legend
Sun, Jan 8, 2006 at 10:16:56 PM
Floor Legend
Thu, Nov 2, 2006 at 10:35:07 AM
Page generation time: 0.1762
