Forums >> Revit Building >> Technical Support >> image parameter?
Mon, Oct 12, 2009 at 3:33:29 PM | image parameter?
jhendershot
i am looking to store an image within a family that is able to schedule so when you create a schedule of say equipment you can have a column with the equipment's image in the schedule.
i created something similar in Architectural Desktop a couple years ago that would auto create a wall type schedule depending on the partitions that were in the model including images and sections of said walls... although a bit different the concept of storing an image with a block/family is the same.
is this possible?  Cryingand no i don't just want a URL link..an actual image is perfered)
thanks.
Mon, Oct 12, 2009 at 4:10:18 PM | image parameter?
jhendershot
forgot to mention this is Revit Architecture 2009, but might be moving to 2010 in the near future so if it can work on that please don't hold back..
 cheers!
j.
Mon, Oct 12, 2009 at 4:26:29 PM | image parameter?
tim123
4 Stars: 19 Votes
I don't think that what you're trying to achieve is possible.  A URL link is probably your best bet, besides pasting images onto your schedule sheet.
Mon, Oct 12, 2009 at 4:33:14 PM | image parameter?
jhendershot
thanks for the reply.. i didn't think it was going to be possible.. i have been reading all kind of info and i am pretty familar with creating families and never came across anything that would allow me to do it, but thought i would ask in case i was missing something.
thanks.
j.
Wed, Sep 19, 2018 at 5:25:39 PM | image parameter?
MarcoMendez
4 Stars: 1 Votes
Contact me i can solve your problem
Parameter formulas to select between two types then a instance
Sun, Jul 8, 2012 at 5:30:37 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
Parameter Formula
Tue, Feb 27, 2007 at 7:12:50 PM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
Raster Image display
Fri, Oct 10, 2008 at 6:08:26 AM
Page generation time: 0.3273
