9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Wall type graphics
3 Posts No Rating |
I'm working in Revit Architecture 2010. I want to create a property within a wall type with the fire rating of the wall. Then I would like to associate this property with a graphic that would appear when the wall is cut in plan or section. For example if the wall is 1 hr rated and I cut it in plan then a light dashed line would appear, but if it's 2 hr rated then a heavy dashed line would appear. Is this possible?
No... sorry. You can use coarse fill patterns but most of us don't feel that works so we all use lines on our rated wall plans. You can lock the lines to the CL of the wall.
50 Posts No Rating |
You could create two different walls (for each fire rating). Each wall would be made of a different material that would coorespond to the hatch pattern you are looking for. Well, this would work as long as it does not mess up any wall schedules... MB
Wall Thickness in Type Parameter |
Fri, Jun 1, 2018 at 7:39:15 AM
Wall Type Graphic - Not Rotating with Wall |
Thu, Mar 24, 2016 at 2:47:22 PM
Glass wall (not curtain wall) problem with nvidia quadro fx graphics card |
Tue, Jan 12, 2010 at 2:23:04 PM
Wall Sweep vs. Wall Type |
Mon, Mar 7, 2016 at 10:36:59 AM
Wall Graphics from Plan View |
Tue, Nov 12, 2013 at 5:39:17 PM
