9 Users Online (8 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 10.12.09: Revit’s “Center” Command
Mon, Oct 12, 2009 at 10:56:00 AM | Revit TotD – 10.12.09: Revit’s “Center” Command
rkitect
rkitect Avatar
4 Stars: 29 Votes
I will never forget when someone asked me where the “center” command is in Revit.  I was actually stumped for about half a second, before I proudly and in a fashion my grand-dad would be proud of answered with the following:
The center between two objects (midpoint along a line stretching between two objects) can be found a couple of ways, the easiest is through the midpoint snap (’SM’ on your keyboard).
TotD-101109-1
But sometimes, you just have too many lines all bunched up on top of each other and you need to know that you have the right center point.  The alternate, and slightly more accurate, method of finding a center between two objects is demonstrated by simply placing a Reference Plane (or a detail line if you’re dealing with sheets) between the two objects
TotD-101109-2
Dimension between the two objects and the Reference Plane
TotD-101109-3
And click the ‘EQ’ that appears above the dimension when it is selected.
TotD-101109-4
This will place the Reference Plane an equal distance from both objects, and unless my geometry teacher was completely wrong, that is the midpoint between the two objects, also known as “Centering” an object (in this case a Reference Plane).  You can also do this with other objects such as Doors and Windows.
TotD-101109-6
TotD-101109-7
Well, like I said; a nice easy one to ease my way back into the mix.  Stay tuned for the next Revit TotD!
You can of course read this post in its entirety at http://revittotd.com/10/719 with all the pics and video!
-Carl
revit_arch_09_cert_pro_rgb
Edited on: Mon, Oct 12, 2009 at 10:56:27 AM
Revit TotD – 2.19.10 | Dimension Formulas
Fri, Feb 19, 2010 at 10:29:46 AM
Revit TotD – 7.5.09: Let that Bump do the Work
Wed, Aug 5, 2009 at 9:52:58 AM
Revit TotD – 7.30.09: Revit 2010 Add-In Manager
Thu, Jul 30, 2009 at 7:08:14 AM
Revit TotD – 7.29.09: Don’t Skip the SKP Mats
Wed, Jul 29, 2009 at 9:24:55 AM
Revit TotD – 7.9.09: Glowing Sign, Self-Illumination Based Materials
Thu, Jul 9, 2009 at 2:20:36 PM
Page generation time: 2.2892
