11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Rotating Project North and Sheet view North not rotating
15 Posts No Rating |
I have researched this subject in the forum and viewed a Project North video recommended in the Forum. My question is this. I have drawn a building, created views and sheets and have now learned that the building needs to be rotated 90 degrees. I can do this OK, the problem is due to the building shape I need the views to be rotated 90 degrees to fit on the sheet. I have rotated the "Project" North which does rotate the building, however the North arrow on my sheet title is still facing up. I need the North arrow to face to the left "True North". Any help would be greatly appreciated. Thanks Dan Iacovoni
HI Unfortunately the north arrow on a sheet is not linked to true north, nor can it be done (to my knowledge) at this stage. You will have to edit you sheet family for your project and rotate the north direction as required.HTH
Edited on: Sun, Oct 11, 2009 at 9:50:25 PM
Thank you for the response. When I rotate my view, the Plan tag rotates as well, rotating the text 90 degrees. Is there a way to rotate the view and not the tag.
Rotating views to project north |
Mon, May 28, 2007 at 3:46:10 PM
How to Rotate True North without rotating the whole Project? |
Thu, Mar 18, 2010 at 7:25:35 PM
Problem rotating project to define True North- not everything rotates. |
Sat, Nov 29, 2008 at 5:30:02 PM
Rotating project north (I've done stuff wrong and need help) |
Wed, Nov 23, 2011 at 11:37:52 AM
project north/true north |
Thu, Mar 17, 2005 at 5:00:19 PM
