Forums >> Revit Building >> Technical Support >> Family in Cut plane
Sun, Oct 11, 2009 at 12:46:50 PM | Family in Cut plane
Newcommer
Hello,
I am a new commer. Why 5'tall balcony separation wall (Wt parapet cap family on top) is
overlapping the cut column and walls? Pleasee see the attached jpg for reference. I am using
R Arch. 2010.
Thanks
Sun, Oct 11, 2009 at 10:12:40 PM | Family in Cut plane
eldados
eldados Avatar
4.5 Stars: 8 Votes
check that your cut plane is not above the parapet.
Integrator
KarelCAD
Mon, Oct 12, 2009 at 10:50:12 AM | Family in Cut plane
Newcommer
Thanks for your help.
Yes I did. It is 4' above. And I also test that in a  new file, the same problem occures. There are two
problems that I have noticed, firstly if the wall is lower than 6', cut line doesn't show up, secondly, any
shorter wall has overlapping display. It is simillar to display order in CAD. Pls see the attachment.
thanks
Mon, Oct 12, 2009 at 10:59:15 AM | Family in Cut plane
Newcommer
thanks
How to control where the cut plane is for families?
Sun, Nov 22, 2009 at 10:19:59 AM
Generic model cut plane & plan regions
Thu, May 20, 2010 at 6:44:22 AM
Cut plane problems with Families - Revit 2013
Tue, May 21, 2013 at 2:29:27 PM
Cut framing with ref.plane in families?
Thu, Apr 8, 2010 at 7:18:06 AM
window above cut plane is visible. why?
Fri, Nov 27, 2009 at 9:25:10 AM
Page generation time: 5.3014
