19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Wall wrapping issue
39 Posts No Rating |
I have a project with some tight wall angles and my wall wraps are not working correctly. I have tried the join modify tool, tried adjusting the wall snaps, and changed the location lines. I have attached a Revit project file of the walls in the configuration I am working with. If someone could tell me what I am doing wrong I would appreciate it. Daryl Stockton
Joins and wraps are two different issues. Revit does not like short jogs in walls. If that is your issue, search the forums under joins and you will find posts that will tell you how to solve this.
One way to get round the problem (which occurs when the length is less than the width) is to divide the wall into components and join them. The image shows the stone face and CMU as one wall and the timber and gypsum as a separate wall.
wall layers not wrapping at curtain wall inserts! |
Fri, Mar 4, 2016 at 10:27:08 PM
wall wrapping problems |
Wed, Mar 4, 2015 at 9:59:02 AM
wrapping wall materials |
Thu, Aug 14, 2008 at 4:40:22 PM
wrapping of wall inserts |
Fri, Jul 14, 2006 at 5:13:18 PM
Wall wrapping |
Thu, Jun 17, 2004 at 6:15:29 AM
