Forums >> Revit Structure >> Technical Support >> How do I use a geometry created in AutoCAD as a Revit Roof?
Thu, Oct 8, 2009 at 11:37:33 PM | How do I use a geometry created in AutoCAD as a Revit Roof?
mlodge
We are creating a roof that involves complex curved geometry. We have resorted to using the loft tool in AutoCAD to produce the form which has worked fo us. I am now unsure how I can import this into a revit model so it functions as a 'roof', allowing us to attach walls etc to it. Does anybody have any suggestions?  We are using Version 2009.
Fri, Oct 9, 2009 at 4:51:11 AM | How do I use a geometry created in AutoCAD as a Revit Roof?
4 Stars: 205 Votes
Simple, if your CAD obj. is a ACIS solid in Revit go to "massing" create a new mass, import the DWG file, finish the mass then apply "Roof By Face".
Converting AutoCAD 3d Solid in to a Revit Roof
Thu, Nov 17, 2011 at 2:47:17 PM
importing from AutoCAD
Thu, Jul 19, 2007 at 1:47:15 PM
Default how to convert autocad blocks (inserts) into components (family instan
Fri, Nov 9, 2007 at 5:12:51 PM
Cropping an AutoCAD file inside Revit?
Thu, Mar 12, 2009 at 7:19:04 AM
13
Trouble with join geometry with Roof fascia
Fri, Oct 18, 2013 at 10:26:02 AM
Page generation time: 2.2245
