Forums >> Revit Building >> Technical Support >> Mullion Joins Issue
Thu, Oct 8, 2009 at 12:21:38 PM | Mullion Joins Issue
SRobbins1977
I have a problem with a mullion shape (SEE IMAGE). As you can see the shape of the mullion is causing the mullions adjacent to it, to stop before they come together(see high lighted red).  I would like the to come up snug to the mullion the red arrows are pointing to.
Any help would be fantastic.Thank you,~Scott
Thu, Oct 8, 2009 at 12:41:57 PM | Mullion Joins Issue
4 Stars: 205 Votes
Did you try the "Make Continuous" tool?
Thu, Oct 8, 2009 at 3:01:25 PM | Mullion Joins Issue
SRobbins1977
Hi Typhoon,
I should clarify a bit, that tool will simply present the same problem only in vertical direction instead of the horizontal direction.  I don't need the horizontally divided mullion to connect to its other half.  I just need to join snugly against the adjacent vertical mullion.
Thank you
~S
Thu, Oct 8, 2009 at 3:51:38 PM | Mullion Joins Issue
A step faced muillon does not wok well in REVIT.  One workaround is to have tw CW's in the same place.  One with the back profile of the mullion and one with the front.  You can still schedule correctly using filters.
mullion issue
Wed, Jul 13, 2011 at 1:07:49 PM
Curtain System from Mass - Mullion Joins
Fri, Dec 11, 2015 at 7:27:44 PM
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:08 PM
mullion join at angled mullion 2017
Sat, Oct 21, 2017 at 11:53:54 AM
Page generation time: 0.2367
