Forums >> Revit Building >> Technical Support >> Walls – Coarse, Medium and Fine or...
Thu, Oct 8, 2009 at 12:12:01 PM | Walls – Coarse, Medium and Fine or...
SRobbins1977
In my case Coarse, Fine, and Fine.
I'm building some Revit walls and would like for someone in a plan view to be able to switch between the diferent detail levels.  When they switch between the detail levels in a plan view I would like them to see COARSE as 2 lines, MEDIUM as 4 lines(highlighting the core) and for FINE all layers of the wall.  But instead when a view is switched to MEDIUM we get all layers of the wall. Has anyone dealt with this?
Thoughts please.Thank you,~Scott
Thu, Oct 8, 2009 at 2:38:35 PM | Walls – Coarse, Medium and Fine or...
mhans
3 Stars: 10 Votes
Please check your visibiliy/graphics overrides. See that under the Visibility Column -Wall- Detail Level (last column) is set to "by view".
Motto: "No Post left behind"
Thu, Oct 8, 2009 at 2:52:09 PM | Walls – Coarse, Medium and Fine or...
SRobbins1977
Yes they are by view.  Sadly Medium and Fine both still show all layers.
Thu, Oct 8, 2009 at 3:19:49 PM | Walls – Coarse, Medium and Fine or...
mhans
3 Stars: 10 Votes
I tried a couple of built-in walls in Revit and found out that Medium and Fine settings are the same. I tried creating my own wall and medium and fine has no significant difference.
Different colors in Coarse/Medium/Fine?
Mon, Sep 13, 2010 at 9:28:50 AM
Coarse, Medium, and Fine Settings
Wed, Dec 28, 2011 at 12:27:19 PM
sloping roof joists only displays on medium/fine
Tue, Mar 31, 2009 at 1:33:01 PM
Coarse Fill Pattern for Footings and Foundation Walls
Wed, May 30, 2007 at 3:38:16 PM
Fine, medium, course view option not available!
Mon, Mar 10, 2014 at 9:52:32 AM
Page generation time: 1.0533
