Forums >> Revit Building >> Technical Support >> Creating new project from existing
Mon, Aug 22, 2005 at 11:28:58 AM | Creating new project from existing
jclark53
I need to create a totally new project from and existing one. Is there a simple way to transfer ALL data and give it a new project name? Post edited on 2005-08-22 11:29:44
Mon, Aug 22, 2005 at 11:36:15 AM | RE: Creating new project from existing
TomDorner
4.5 Stars: 25 Votes
Provided the project is not a central project, simply open the current project and do a "save as" or copy using Windows to new location and rename. If the project is a central project, then it depends on what version you are using. If worksetted and central in 8.0 or less, open the central file on the server and do a save as being sure to make a new cental file location for a different project.. If using 8.1 you can experiment with the new detach from central command which I have not played with yet. If anyone else knows better/easier ways chime in. HTH Tom
Mon, Aug 22, 2005 at 12:16:53 PM | RE: Creating new project from existing
jclark53
Thanks. Yes it is a central file in 8.0. That's why I was having problems. We have just received 8.1 and have not installed it yet. Will have to try the new command.
Creating Existing Footings in Revit Structure
Mon, Jan 4, 2010 at 12:09:19 PM
CREATING LEVEL IN NEW PROJECT.
Mon, Jan 6, 2014 at 10:00:33 AM
Creating existing plan
Fri, May 21, 2004 at 9:36:50 AM
Stupid ? # 234 - project browser
Fri, Nov 20, 2009 at 1:23:50 PM
Existing Elevations not Referencing Existing Plans
Thu, Dec 5, 2013 at 3:57:29 PM
Page generation time: 1.7360
