Forums >> Revit Building >> Technical Support >> Does anyone know if there is something similar to xrefing in Revit?
Thu, Oct 8, 2009 at 8:25:00 AM | Does anyone know if there is something similar to xrefing in Revit?
victorpachecojr
Hello everyone, does anyone know if there is something similar to xrefing in Revit? I am working on a 16 story condo project and levels 6 thru 14 are exactly the same. Anytime I make a change to level 6 I have to copy up again levels 7 thru 14. Is there a way to link levels 6 thru 14 so that I only have to make a change at level 6 and all the other level would automatically change just like using xrefs in AutoCAD. Any help would greatly be appreciated. Thanks, vp
Victor Pacheco Jr.Architectural Project ManagerTampa, Florida  USAvictor.pacheco.jr@gmail.com
Thu, Oct 8, 2009 at 9:17:42 AM | Does anyone know if there is something similar to xrefing in Revit?
TKennedy
4 Stars: 8 Votes
Someone may know a better way than this, but I would try creating and copying a group.
Thu, Oct 8, 2009 at 9:24:37 AM | Does anyone know if there is something similar to xrefing in Revit?
victorpachecojr
TKennedy, thank you for the suggestion I will try it out. Thanks, vp
Thu, Oct 8, 2009 at 12:42:17 PM | Does anyone know if there is something similar to xrefing in Revit?
Read your HELP on LINKS.   I hate to use the term x-ref because Revit's file linking is very different.  You can link in CAD, DWF's or REVIT projects.
Thu, Oct 8, 2009 at 1:16:51 PM | Does anyone know if there is something similar to xrefing in Revit?
DarkenRahl
If they are exactly the same, does each floor need its own fully modelled level?  Why not model one floor fully, then use that as the typical floor plan.  Then you can leave all of the duplicate geometry of other floors out, saving you resources and time.
Edited on: Thu, Oct 8, 2009 at 1:17:14 PM
Thu, Oct 8, 2009 at 2:05:19 PM | Does anyone know if there is something similar to xrefing in Revit?
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
as wwwhub said, you can use linking system. Just use the import/link button on file column, and all your parts of proyects will update as u work on them. Try to use a different file for every part, like a file for topography, one for other buildings, roads, building A, building B ( in case you need to work on different parts of the proyect) AND A FILE that have it all HOSTED. The real use of what are you asking is when you work on a team, and split the work make all easier.
Sun, Oct 11, 2009 at 8:28:37 PM | Does anyone know if there is something similar to xrefing in Revit?
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Linked files is exactly what you need, make that floor a model of it own and just link it in.
J. Allen Ball
Revit Architecture 2010 Certified Professional
create similar greyed out
Wed, Apr 26, 2017 at 3:17:40 PM
Similar Tags - Interior Elevation
Fri, Oct 24, 2008 at 10:32:16 AM
Similar Callouts
Fri, May 12, 2006 at 4:25:50 PM
Sat, Dec 23, 2006 at 10:12:14 AM
Workset
Wed, Apr 27, 2005 at 11:12:07 PM
Page generation time: 1.5564
