Forums >> Revit Structure >> Technical Support >> Adding roof bar joists on different hight brg. ends..
Tue, Oct 6, 2009 at 12:37:04 PM | Adding roof bar joists on different hight brg. ends..
fleming3310x
I am a revit structure newbie (long time autocad user)... We are doing a project that has bar joists brg. on cmu ICF and CMU walls.. the joists are higher on one end and slope to the other end... I can get the joists to slope if I do them one at a time, but if I try to do a system of them they are level with the floor..
 I will say I am very frustrated in learning revit, I am the head cad guy at our firm and I have read mastering revit structure and am just struggling in general.. People I talk to either love it or hate it..
any idea of being able to do these as a system..
Tue, Oct 6, 2009 at 1:02:33 PM | Adding roof bar joists on different hight brg. ends..
4 Stars: 205 Votes
Hi and Welcome to Revit World...
I'm not a "Structural guy" but here you have some sites from struct.: http://bimandbeam.typepad.com/bim_beam/
and:  http://www.revit-waterman.blogspot.com/
Keep learnig and you gonna enjoy Revit....
Tue, Oct 6, 2009 at 1:09:27 PM | Adding roof bar joists on different hight brg. ends..
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi fleming welcome here....."I will say I am very frustrated in learning revit".....don't give up, just carry on!!!!....practice makes perfect......
Tue, Oct 6, 2009 at 10:51:53 PM | Adding roof bar joists on different hight brg. ends..
markitekdesign
markitekdesign Avatar
4.5 Stars: 74 Votes
Just be patient,more practice...may be next time you can do it...right...
https://www.facebook.com/groups/257952100885689/
''GOOD WORK IS NEVER CHEAP,AND CHEAP WORK IS NEVER GOOD"
Thu, Oct 8, 2009 at 8:29:36 AM | Adding roof bar joists on different hight brg. ends..
JACMD
you can put a reference plane and use it to create your beam system.
another way that I've done it (don't know if its a good way or not) is un-pin the joist and give the correct elevation in the properties window (start & end elevation). hope this helps
Fri, Oct 9, 2009 at 12:02:50 PM | Adding roof bar joists on different hight brg. ends..
emgeeo
3.5 Stars: 7 Votes
First thought- create a reference plane defining the geometry (slope) you want the top of your bar joists to adhere to.
Just re-name your reference plane (in the element properties box) after you've drawn it.
After you've renamed it- simply select the reference plane from the design bar when placing new beams and joists.  It will draw the joists along that reference plane.
In terms of making chages- make changes to the reference plane, not the individual joists.
You can also use framing systems to slope framing.  If you go to a section and select the system (NOT the individual framing members) you'll see a 'reference plane' show up.  You can rotate this reference plane by disjoining it (an option on the design bar) but I would not call this a preferred method.
Does that make sense?
Sloping Bar Joists?
Thu, May 7, 2009 at 9:41:08 AM
Sloping joists to the roof deck
Mon, Apr 4, 2016 at 11:21:15 AM
Manipulating Bar Joists
Fri, Feb 16, 2007 at 12:32:07 PM
wall display properites
Thu, Sep 18, 2008 at 11:06:37 AM
AAARRRGGGHH! Joist questions!
Thu, Nov 17, 2011 at 11:35:04 AM
Page generation time: 0.9701
