26 Users Online (24 Members):
Forums >> Revit Structure >> Technical Support >> existing floor system
5 Posts No Rating |
I have an existing 2" concrte slab over 2" metal deck. When it is new construction it shows the slab and the deck profile. When it is existing it is shown blocked out. Is there a way to show the deck profile for an existing floor system?
5 Posts No Rating |
If I change the phase filter to 'by category' instead of 'overriden' it will show the profile but it has new construction lineweights. Is there a way to get the lineweight back to existing?
My recommendation is to copy the deck/slab type and rename it with 'exist' in the name. Example might be something like: Exist 3" Conc on 2" Deck Then, create and apply a filter as needed. If you don't know how to do that, let me know and I can help.
5 Posts No Rating |
That worked. Thanks.
I have this same problem but my firm's standards is to show all existing construction with a dark gray infill. I need the phase for existing objects to be overridden with the cut pattern to a solid gray. Why does Revit get rid of the deck profile when this is set up this way?
new opening in an existing floor |
Tue, May 15, 2007 at 3:49:38 PM
11
Raised floor system |
Thu, Jun 25, 2015 at 2:10:09 AM
adding a render system to an existing wall |
Fri, Jan 16, 2009 at 4:57:25 AM
why can't the architectural floor system show joists? |
Tue, Mar 25, 2008 at 12:55:30 PM
Existing Elevations not Referencing Existing Plans |
Thu, Dec 5, 2013 at 3:57:29 PM
