Forums >> Revit Building >> Technical Support >> Revit will not finish rendering ???
Tue, Oct 6, 2009 at 5:37:49 AM | Revit will not finish rendering ???
Jatujak
This problem has just come up today... Was rendering the exterior area around my pool. Completed about 15%, then it just jumped to 100% and stopped rendering...I have tried all light settings (Artificial and Sun etc). I have revit 2010
Please I really need quick help this is  due on Friday Sad
Tue, Oct 6, 2009 at 8:54:57 AM | Revit will not finish rendering ???
4 Stars: 205 Votes
Did you install the "Web Updates 1 & 2" for Revit 2010 from Autodesk?
Wed, Oct 7, 2009 at 1:53:07 AM | Revit will not finish rendering ???
Jatujak
I installed an update that Autodesk recomended in an email, although I'm not sure what it was exactly...it was around 100mb.
Wed, Oct 7, 2009 at 4:13:13 AM | Revit will not finish rendering ???
4 Stars: 205 Votes
Solve the problem?
Wed, Oct 7, 2009 at 5:01:24 AM | Revit will not finish rendering ???
Jatujak
Nope. It may actually be the cause of the problem..this never happened before I updated. But I don't think it started STRAIGHT after the update, it was kinda delayed.
I found that rendering with the option of "One day solar study" fixes it, but it doesn't work on the others. Just skips from about 50% straight to 100%.
Wed, Oct 7, 2009 at 7:06:23 AM | Revit will not finish rendering ???
Probably hardware issues... please describe what U have.
Thu, Oct 8, 2009 at 1:21:03 AM | Revit will not finish rendering ???
Jatujak
Q9450 @3.4ghz
6GB RAM @ 1021mhz
Asus P5K Pro motherboard
2tb harddrive space
4870 512mb
Thu, Oct 22, 2009 at 12:53:28 PM | Revit will not finish rendering ???
brainatoms
I have had the same problem, so I cut back some of the rendering parameters that eat up time and memory (soft shadows, reflections, refractions, etc.). I also broke the rendering into peices to be assembled later, but have been unable at successfully exporting the image(s). I read here (http://www.revitcity.com/forums.php?action=viewthread&thread_id=11975) that printing the rendered image to pdf may be the answer, but I am waiting on the rendering to finish to try. I'll report back when I find out.
Perhaps our friendly site moderator could describe program limitations relating to file size or why we'd be able to render a large image, but not save the file.
Fri, Oct 23, 2009 at 8:16:13 AM | Revit will not finish rendering ???
brainatoms
can't "print" a rendering from screen to pdf, export only.
Thu, Sep 24, 2015 at 8:31:13 AM | Revit will not finish rendering ???
andy777bennett
this was never resolved? here in revit 2015 ur9 I get the same thing
fx8370
asrock 990fx extreme 4
Corsair ax 860
Thu, Sep 24, 2015 at 8:37:49 AM | Revit will not finish rendering ???
#11
This is not an issue to be resolved - it is process.   If you save the image to the project, it can be printed.
You can save the image into the project file but unless we will be placing the image on a sheet, we prefer to export the image to a file to keep our file size down.
Thu, Sep 24, 2015 at 8:55:45 AM | Revit will not finish rendering ???
#12
andy777bennett
sorry was not refering to exporting the image, the rendering skips to 100 so there is no image to export.
Thu, Sep 24, 2015 at 10:02:00 AM | Revit will not finish rendering ???
#13
An incomplete rendering is not a typical problem so I don't believe it is a software issue.   The problem is probably your system and maybe the complexity of your file and we know nothing about that.
Thu, Sep 24, 2015 at 1:25:01 PM | Revit will not finish rendering ???
#14
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
What happens when you set the rendering quality to 'Draft' and or use the 'Region' option ? . . . . . basically get any Render to complete regardless of the results.
Fri, Sep 25, 2015 at 7:09:30 PM | Revit will not finish rendering ???
#15
andy777bennett
I tried in the revit default project in 2014 and 2015 with similar results. draft, sun, and region do not seem to make anything different with the exception of draft because it completed faster than it crashes.
I am overclocking my cpu more than normal. nothing is overheating and seems odd that this would happen
rendering walkthrought
Tue, Jul 25, 2006 at 10:28:49 AM
How do you tell what finish has been applied with Paint?
Sat, Jan 26, 2013 at 5:14:41 AM
metallic finish in render
Thu, Aug 15, 2013 at 2:41:56 AM
Memory Hog
Fri, Jul 27, 2007 at 3:58:49 AM
Rendering in Revit
Fri, Apr 17, 2009 at 4:32:29 AM
11
Page generation time: 1.7220
