15 Users Online (13 Members):
Forums >> Revit Building >> Tips & Tricks >> Finish Schedules, Finish Elevations and Plans
10 Posts No Rating |
I've recently found a workaround for calling out the proper finishes on my plans. I was trying to make my finish schedule be linked to my elevations and plans so that there is less chance for error as is the goal of the entire Revit program. So I created 4 shared parameters. West East North and South in my room parameters. Next I created 4 custom "Room Tags" Called West East North South. Then I used these different tags in my elevations making sure the right tag was used in the right elevation. So then when I punched in a finish for a wall it showed up in my schedule. Not sure if this helps anyone but it will save me a lot of effort in my hotels.
3 Posts No Rating |
I was trying to duplicate approach from your post but was having trouble with the room tag families. Could you send me one of tags? Will
See if this works for you. I might have made a shared project parameter, I'm not sure.
3 Posts No Rating |
Thanks for the quick reply. No problem making the Room properties show the shared parameters for North, South, etc. but how do you get the custom Room Tag, for instance"West", to link to the schedule so that you can input a finish in either the tag on the elevation or the schedule?
I made a room schedule and added a shared parameter from my shared parameter text file. The same file that I liked my tags to.
3 Posts No Rating |
Figured it out but thanks for your help.
Color Schemes in Finish Plans |
Tue, Jul 26, 2011 at 12:56:15 AM
Finish Schedules |
Mon, May 16, 2011 at 11:26:52 AM
rom finish tag |
Mon, Apr 23, 2007 at 7:55:22 PM
Room Finish Schedules |
Mon, Feb 14, 2005 at 5:45:05 PM
Finish Material Schedule |
Tue, Nov 29, 2005 at 12:31:59 PM
