Forums >> Revit Building >> Technical Support >> Revit 8 to Revit 8.1
Sun, Aug 21, 2005 at 10:21:28 PM | Revit 8 to Revit 8.1
bjamin
I loaded 8.1, now I cannot draw any walls on any of my 8.0 projects. Can anyone help? bjamin
Sun, Aug 21, 2005 at 11:39:01 PM | RE: Revit 8 to Revit 8.1
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
That sounds a bit strange... What do you mean by you can't draw any walls? Upgrading to 8.1 should have no effect on any functionality.
Mon, Aug 22, 2005 at 12:09:52 AM | RE: Revit 8 to Revit 8.1
bjamin
I get a messenge " can"t make wall". When expanded error "Cryingdeleted element): id 945431". I tried to open a saved version (pre 8.1) of project on 8.0 and it also gave me the same message. I have since removed and reloaded both programs, then loaded a saved disc of the program (had to go retreive from a client's office) and now I am no longer getting this error and can draw walls again. But still don"t know what caused this or if it will happen to files that I open Later. Post edited on 2005-08-22 00:12:44
convert revit 7 in revit 6.1
Wed, Jun 15, 2005 at 9:49:02 AM
**ATTENTION ALL REVIT GURUS** - Teaching Revit
Mon, Oct 6, 2008 at 9:30:42 PM
Revit 2009 : Coordination Between Revit Structure & Revit building
Fri, Jun 20, 2014 at 10:41:34 AM
Translating Revit 7 projects (And Office-particular) Library families into Revit
Tue, Jul 19, 2005 at 12:00:00 PM
Nested parametric use from Revit 6.1 to Revit 7
Tue, Nov 30, 2004 at 9:33:34 PM
Page generation time: 2.6690
