Forums >> Revit Building >> Technical Support >> Issue while duplicating view and changing view scale
Sat, Oct 3, 2009 at 9:12:15 AM | Issue while duplicating view and changing view scale
LaCucha
Hello,
I am trying to create a duplicate floor plan (1/8" view scale) from my standard 1/4" scaled floor plan.  To do this, I use the following steps:
1. Click the desired floor plan.  2. Right click and select duplicate view - duplicate with detailing.  3.  Open the duplicate floor plan.  4. Change the view scale from 1/4" to 1/8".
The problem: After changing the view scale, the annotations do not change scale.  Annotations include all text, dimension text, room labels, tags, etc.  See the first attached image for an example of my floor plan after I changed the view scale.  Is there a way to fix this?  Do I need to change the text sizes manually?   The room labels are also dependent on the parent floor plan.  Changing the room label text size, etc, in the duplicate floor plan changes the text size in the parent floor plan.  Help!
Also, is it possible to decrease the spacing between text lines in revit?  Is it possible to decrease the space between text and a corresponding leader?  The last two images show my current spacing between text lines, and spacing between text and leader.
I am using Revit version 10.  I really appreciate anyones help!
Thanks, Bret
Sat, Oct 3, 2009 at 10:21:37 AM | Issue while duplicating view and changing view scale
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
No images...
J. Allen Ball
Sat, Oct 3, 2009 at 5:40:03 PM | Issue while duplicating view and changing view scale
LaCucha
Oops!  Sorry about that.  This is my first thread.  Let me try attaching those images again...
I hope it worked this time.
Thanks again for anyone's help, Bret
Sat, Oct 3, 2009 at 5:47:29 PM | Issue while duplicating view and changing view scale
LaCucha
Okay then....
Looks like Tiff images do not work.  Let me try attaching JPEG.
Thanks, Bret
67049_After_Decreased_View_Scale.JPG67049_Text_Spacing.JPG67049_Space_Between_Text_and_Leader.JPG
duplicating views without duplilcating callouts or view tags
Wed, Sep 11, 2013 at 3:09:15 PM
Changing Elevation Parent View
Tue, Nov 9, 2010 at 4:35:05 PM
Scale of Text in Views?
Thu, Jul 17, 2008 at 7:37:17 AM
Re-scale the 3D View
Wed, Jan 22, 2014 at 3:20:59 AM
View Title scale text won't show
Tue, Dec 29, 2009 at 2:36:51 PM
Page generation time: 0.9696
