Forums >> Revit Building >> Technical Support >> How to draw unattached dimensions
Fri, Oct 2, 2009 at 3:12:09 PM | How to draw unattached dimensions
ShadowVFX
I've just started using revit yesterday and I did a search but couldn't find the answer to what I was looking for, so I'm posting it here.
How can I make a dimension that goes from point A to point B, even if point A and/or B are not a line, endpoint, or any piece of geometry? I know in AutoCAD you can simply draw a dimension from anypoint to another point, regardless of if there's geometry or not. Is there a way to do this in Revit?
Does this make sense? If not, let me know and I can try to explain it a bit more clearly.
Fri, Oct 2, 2009 at 5:58:38 PM | How to draw unattached dimensions
pepsiqueen
pepsiqueen Avatar
as far as I know you need to have something to reference to. In teh past i have drawn white lines and used those, that way they dont show up when you print. but then you lose the parametric beauty of the program...
I'd rather be riding at whistler. or highland. thats good too.
Sat, Oct 3, 2009 at 2:53:04 AM | How to draw unattached dimensions
nafenn
I'm not meaning to be rude or anything, but why would you want to??
I used to use ( lets call them fake dimensions for lack of a better word) in autocad but revit forces you to draw everything accurately and therefore dimension everything accurately.
Sat, Oct 3, 2009 at 10:26:40 AM | How to draw unattached dimensions
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
or create another dimension type and have it set to round up to the closest inch or whatever you need.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Sat, Oct 3, 2009 at 12:38:11 PM | How to draw unattached dimensions
pepsiqueen
pepsiqueen Avatar
i cant even think of an example of the last time i had to use 'fake dimensions' but i know i have had to do it. Oh maybe to overlay a hiddel line 3d view i would add dimensions once it was placed on a sheet, because you cant dimension in 3d like you can in sketchup. (maybe you can now i havent tried it for a few releases.)
Sat, Oct 3, 2009 at 6:19:32 PM | How to draw unattached dimensions
josta
1 Stars: 1 Votes
When we do it, we use a reference plane so we can still see what is dimensioned.
John Acosta ARA, Architect
Mountain Architecture, Big Bear Lake CA
Mon, Oct 5, 2009 at 1:34:06 PM | How to draw unattached dimensions
ShadowVFX
I will try the whiteline option and see if that works out for me.
On this topic, I need to draw a dimension down the centerline of some steel pieces, but there's no grip points to attach a dimension to in the center of the structures, so does this mean I'd have to use this white line technique, or is there another way? I included an example of the detail as it looks in AutoCAD
I appreciate the help.
Mon, Oct 5, 2009 at 2:09:20 PM | How to draw unattached dimensions
In Revit, we would have a reference plane in the family (bm) that we can dimension to.....
Do you really dimension to the center of the flanges?  What country / standards to you use for that?
Mon, Oct 5, 2009 at 2:59:42 PM | How to draw unattached dimensions
ShadowVFX
We're a firm in the US. While I might be fresh out of college, the last 5 firms I've interned or worked at have done dimensioning like this in some form in at least one detail or drawing. I wouldn't consider this something absolutly insane or off-beat.
Edited on: Mon, Oct 5, 2009 at 3:00:26 PM
Wed, Jun 29, 2016 at 2:40:12 PM | How to draw unattached dimensions
JHARevit
1 Stars: 1 Votes
I'm wondering if the new releases of Revit have brought some change to this inability.  The reasoning I have for the need is to create our wall type schedule (attached as photo).  Do I have to create this as a detail, with basic lines, rather than a legend that contains the literal wall type inserted?
Wed, Jun 29, 2016 at 2:57:13 PM | How to draw unattached dimensions
#11
We use legend components but we add small yick lines for dimensioning.
Temporary Dimensions display problems
Thu, May 13, 2010 at 1:43:10 PM
Mon, Jun 30, 2014 at 9:57:47 AM
Dimensions and Leader Lines
Tue, Feb 1, 2005 at 5:47:18 PM
Should I draw house at angle?
Tue, Aug 3, 2010 at 9:49:32 PM
Measure / Dimensions question
Mon, Jun 30, 2008 at 7:34:23 AM
Page generation time: 0.1687
