Forums >> General Discussion >> Revit Project Management >> changing type of a family from wall based to face based
Fri, Oct 2, 2009 at 1:05:47 PM | changing type of a family from wall based to face based
jcrocco
3 Stars: 1 Votes
I have a water closet family that the architects want me to use, but theirs is wall based, and it wont go into our drawings, as we dont own the wall as it is a linked model.
How can I change a wall based family to be face based?
If I copy over the geometry and the ref planes to a new face based template, I lose some parameters and family types.
Fri, Oct 2, 2009 at 1:19:24 PM | changing type of a family from wall based to face based
And there in lays one of the biggest pains of revit !!!
Sorry - I got no help for U....I have not found any easy ways of changing hosts.
Fri, Oct 2, 2009 at 2:47:44 PM | changing type of a family from wall based to face based
chanus
Did you try grouping the objects in the original family template, then coping and pasting that group into the new family template?
The bottom line is you will loose some information. The art is finding which method of getting the data from one to the other while loosing the least amount of it.
Good luck.
Sun, Oct 4, 2009 at 7:04:00 PM | changing type of a family from wall based to face based
Atraktzi
Been in this situation many times before. I would try the grouping method, but i think the parameter info still gets lost.It's the kind of thing that could cost you a lot of time in trying - I would copy the forms across, an put the work in to update the parameter settings etc, as you need.
Best thing to do is not use wall based fams for anything! (obviously it sucks when you receive stuff that is, but what can you do!).
I know that didnt help much, but had to rant.
Good luck
Tue, Oct 6, 2009 at 7:11:50 AM | changing type of a family from wall based to face based
MARS1276
1 Stars: 1 Votes
If this is a linked file; couldn't you just draw a generic wall for where it is suppose to go and then just hide it?
Tue, Oct 6, 2009 at 8:36:19 AM | changing type of a family from wall based to face based
jcrocco
3 Stars: 1 Votes
I have thought of that but never tried it.  I have never yet made a wall, and I wasn't sure how it would show up on the architectural side.
I was able to modify their families to add connectors, so maybe that is a work around.
Has anyone else tried this successfully?
Tue, Oct 6, 2009 at 10:53:58 AM | changing type of a family from wall based to face based
Dingo46
Dingo46 Avatar
1 Stars: 1 Votes
Copy/ Monitor the linked model wall that the water closet is hosted to ???
Gary
Wed, Mar 3, 2010 at 8:24:37 PM | changing type of a family from wall based to face based
smitholino
i found a relatively easy fix.  Search for the subject  Converting Ceiling Based families to Face Based Families.  I have posted a method there, where you nest the wall or ceiling based family into a new face based family.
Good luck.
Changing wall based family to non wall based?
Wed, Nov 10, 2010 at 7:18:22 AM
How would you modify a family from face-based or hosted to one that is not?
Mon, Sep 26, 2011 at 8:39:50 AM
Tue, Jun 12, 2018 at 7:13:41 PM
Face based family not detecting correct face
Sun, May 14, 2017 at 2:00:40 PM
Plan annotations for face based families
Tue, Feb 8, 2011 at 8:59:45 AM
Page generation time: 2.0531
