Forums >> Revit Building >> Technical Support >> Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
Thu, Oct 1, 2009 at 5:06:25 PM | Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
twhisker
2.5 Stars: 5 Votes
When a sheet has multiple scaled views, the sheet scale label shows "As indicated"  This sucks.  I want it to read "AS SHOWN"  Come on guys - first off, most text is ALL CAPS!!  WHERE can I change this?  I plan to take some API classes at Autodesk University.  Would this be helpful to get under th covers and fix what cant be changed thoruhg the UI?  Any other ideas?  Thanks.
Revit Architecture 2010
Fri, Oct 2, 2009 at 6:35:16 AM | Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
Remember .... RevitCITY is not AutoDESK.
You are welcome to vent here but it will not change this.  Contact AutoDESK.
Fri, Oct 2, 2009 at 10:42:48 AM | Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
twhisker
2.5 Stars: 5 Votes
I realize that!  I was venting AND looking for a work around solution one of you may have come across.  It was also written with humor in mind - guess it didn't go over well. Thanks.
Mon, Aug 29, 2011 at 7:58:12 AM | Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
Lochnesska
Lochnesska Avatar
I would also appreciate if revit could show "1:500, 1:200" like archicad does...
Nessie
Revit 2013
Can titleblock scale only reference one of many views on the sheet?
Sun, Apr 14, 2013 at 10:46:46 PM
Default Scale List editing - how is it done?
Mon, Nov 5, 2012 at 8:53:55 AM
Printing views to scale?
Fri, Aug 31, 2007 at 8:33:25 AM
How do you scale a sheet?
Tue, Nov 7, 2006 at 5:58:13 PM
Scale Value Default Modification
Thu, Apr 2, 2015 at 1:55:43 PM
Page generation time: 0.6137
