Forums >> Revit Building >> Technical Support >> Roofs
Wed, Sep 30, 2009 at 1:24:49 PM | Roofs
Casparos
Hi all,
 how to shorten certain [top layer] compaired to other layers of my roof. Like with walls its possible to modify "vertical structure layers]
I need to end the rooftiles before it encounters the wall, and don't prefer to work with void, inplace families.
 GrC
Wed, Sep 30, 2009 at 3:53:12 PM | Roofs
tim123
4 Stars: 19 Votes
You can do it as two separate roofs.  I typically just have the roof as the tile and batten layer and then a separate, joined roof to include the insulation and rafters.  Depending on the roof, you could do the structure independantly, using a beam system or array of trusses.
joining roofs
Mon, Jan 9, 2006 at 1:20:09 PM
Intersecting roofs
Mon, Oct 16, 2006 at 8:28:41 AM
Problems joining roofs
Fri, Apr 16, 2010 at 10:52:16 AM
Revit 2008 Multiple Roofs on Same level?
Tue, Jul 24, 2007 at 9:05:38 AM
12
Roof problems with 2 gable roofs with different pitches.
Sat, May 1, 2010 at 1:27:57 PM
Page generation time: 0.4200
