10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Schedule fields : numbers & text?
4 Posts No Rating |
Hello fellow revit users - I've been wasting precious billable time to figure out how to input number and text into a schedule field. I am currently running revit 2009 and have a window schedule thats making me want punch my monitor. I have a calculated field to figure window area % (window area / wall area) however some windows on the schedule are exterior and we do not need to calculate thier percentage - in those areas I would really like to put NA within the columns, however being that they are involved in the calculated field I cannot seem to change anything. I attempted some conditional statments (=IF) etc but could not get NA to occur if the window are was <0 . Any help is much apprecitated thanks. eddie loftus
As you have found out, fields in Revit's schedules are limited to their formal. Text can not go in number fields...etc. You could haave two schedules on the sheet placed one above the other with one not having headers. Obviously, this column would be a different field for the filtered schedule.
Schedules combining 2 text fields in to 1 |
Fri, Aug 10, 2007 at 12:27:28 PM
Multiple dimension fields in schedule |
Wed, Aug 24, 2011 at 4:31:08 PM
text in family not display in schedule, fields blank in properties diaglog |
Tue, May 17, 2011 at 6:29:13 PM
Graphical Column Schedule Fields |
Thu, Nov 5, 2009 at 10:30:02 AM
How do I combine fields in a note block with fields in a room schedule?!? |
Thu, Mar 4, 2010 at 3:51:58 PM
