Forums >> Community >> Newbies >> Setting Default Dimension Family
Tue, Sep 29, 2009 at 12:36:12 PM | Setting Default Dimension Family
jrp111
Hi,
First off let me say that I have been using Revit 9.1 for a month or so now and have found this site to be invaluable...
Anyway, this should be a simple answer but I it's driving me crazy.  How do you set a default dimension family? I have 2 dimension families in my project (3/32" & 1/16"Winking  I want to using 1/16" as standard but every new dimension I draw defaults to 3/32".  How do I set 1/16" as default?  I know I'm missing something simple...
Thanks in advance!
-J
Jason Peters
Senior Virtual Construction Engineer
PC Construction Company
Tue, Sep 29, 2009 at 12:50:09 PM | Setting Default Dimension Family
Revit assumes the last one you use is the one you will be using.  So... don't just place a dimension then change its type.  Change the type first and place it.  Next time it should be the same.
Tue, Sep 29, 2009 at 12:50:44 PM | Setting Default Dimension Family
jrp111
Nevermind... I figured it out... sorry for my stupidity!
Jason Peters
Tue, Sep 29, 2009 at 12:55:17 PM | Setting Default Dimension Family
jrp111
Thanks for the reply WWHub... that was exactly it.  I'm Coming from AutoCAD and I'm still getting use to changing settings on the menu bar before drawing.
Jason Peters
Major issue in Family Default Type setting
Thu, Nov 23, 2017 at 8:48:09 AM
Setting a Default Family Type - RAC 2012
Wed, Jan 23, 2013 at 10:09:23 AM
Setting default point for witness dimensions
Mon, Mar 21, 2005 at 11:17:16 PM
Default setting for detail title on inserted drafting views
Thu, Mar 21, 2013 at 9:41:45 AM
default lighting setting for shadows
Mon, Jan 4, 2016 at 10:57:33 PM
Page generation time: 5.6649
