Forums >> Revit Building >> Technical Support >> Sloped sweep in Revit 2010, can it be done?
Tue, Sep 29, 2009 at 10:03:33 AM | Sloped sweep in Revit 2010, can it be done?
jsel13
I have a sloped wall in elevation, and i'm trying to add a sloped coping .  i have the profile but when i add it to the sloped wall it only goes horizontal. how do i slope it?  ive tried to add it to the wall profile itself as well as using the Wall/Wall Sweep command, and neither will work
Thanks!!
(the attached image is an example of both the ways ive tried. its not the finished product, i was just trying to get this to work)
 Cryingversion 2010)
Tue, Sep 29, 2009 at 10:40:58 AM | Sloped sweep in Revit 2010, can it be done?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
" (the attached image is an example of both the ways ive tried. its not the finished product, i was just trying to get this to work)
 Cryingversion 2010)
No attached image..........
Edited on: Tue, Sep 29, 2009 at 11:47:23 AM
Tue, Sep 29, 2009 at 10:57:36 AM | Sloped sweep in Revit 2010, can it be done?
4 Stars: 205 Votes
We don't have the image but use the "Solid Sweep", go to a 3D View then use the "Pick Path" and select one face on the top of that sloped wall, then apply the profile you want....
Tue, Sep 29, 2009 at 11:04:50 AM | Sloped sweep in Revit 2010, can it be done?
jsel13
ill give it a try, and im sorry i thought it was attached. ill try again.
the image on the right is my building. the one on the left was the two ways i tried to do it.
thanks for your help!
Tue, Sep 29, 2009 at 12:32:03 PM | Sloped sweep in Revit 2010, can it be done?
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Typ is exactly correct, except for you will not want to select a face but a 3d edge, and the main thing i wanted to mention here is that if you create a sweep using a 3d edge there is no way to edit without using 3d edges.
But typ idea is your ideal way to go.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Tue, Sep 29, 2009 at 1:04:00 PM | Sloped sweep in Revit 2010, can it be done?
jsel13
thanks guys i got it to work. appreciate the help!
Fri, Jan 11, 2013 at 6:11:13 PM | Sloped sweep in Revit 2010, can it be done?
amszpara
Hi,
I have a similar question, but for the interiors.
I created a room with a sloped ceiling and edited the wall with sweep for cornice. However, after attaching the walls to the ceiling, the sweep stayed at 8 ft, which does not make sense since the shortes wall is still higher than that. The sweep is set to be -3" from the top of the wall. Do you know how to make the cornice sweep follow the sloped wall as well as the different height walls?
I am kind of a newbie and need a clear explanation LOL
Sat, Jan 12, 2013 at 5:22:13 AM | Sloped sweep in Revit 2010, can it be done?
4 Stars: 205 Votes
Same process, Model in-place > Sweep > pick 3D Edges
Slab Edges on Sloped Floors
Wed, Aug 12, 2009 at 12:37:28 PM
sloped glazing in schedule
Wed, Jun 17, 2009 at 10:18:35 AM
Sloped Glazing - version 2010
Tue, Apr 8, 2014 at 12:26:35 PM
Revit 2010
Thu, Apr 15, 2010 at 8:26:48 AM
2010 sweep editing
Wed, Mar 24, 2010 at 4:42:34 AM
14
Page generation time: 1.9112
