Forums >> Revit Building >> Technical Support >> Can't select model items by clicking
Mon, Sep 28, 2009 at 12:42:25 PM | Can't select model items by clicking
yvonnezh
All the model items seem frozen in one of my building elevations (the rest of them are fine). I can't pick any one of the model items. I can only select them by drawing a cross window. And all the related functions, such as dimensions, keynotes, linework tools, etc., does not work anymore because they work by "clicking" items. Anyone had this issue before? I'm trying not to create a new elevation - there were a lot of work on lineworks and dimensions that can not be copied over. Thanks!
Mon, Sep 28, 2009 at 2:50:24 PM | Can't select model items by clicking
mhans
3 Stars: 10 Votes
Are the model items in gray? Did you group them? Does filter work?Can you duplicate the sheet with detailing and check it the same condition exist? This can be from a lot of causes. Save your file to another name or you can open the latest backup file, the ones like filename.rvt.001 and compare.
Motto: "No Post left behind"
Mon, Sep 28, 2009 at 2:59:46 PM | Can't select model items by clicking
yvonnezh
Everything looks normal. I tried to create a new view.
  1. Duplicate  - model items back to selectable but frozen again after applying view template
  2. Duplicate with detail – model items still frozen
  3. Create a new elevation view – works even with applying the view template.
And actually I think I found the answer: when you move your view tag on the floor plan, if you move both the square/circle and the triangle several times, it will lock-up the elevation view. Now I know how it locked but I don't know how to unlock it.
Tue, Sep 29, 2009 at 7:56:48 PM | Can't select model items by clicking
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
does it says it locked? i have never heard of locking a elevation?
J. Allen Ball
Revit Architecture 2010 Certified Professional
Wed, Sep 30, 2009 at 8:13:03 AM | Can't select model items by clicking
yvonnezh
It does not say anything. The properties look the same as the others. You just can't touch the model items - the drafting items are fine.
Wed, Sep 30, 2009 at 12:10:40 PM | Can't select model items by clicking
mhans
3 Stars: 10 Votes
Strange! Can you select all and use filter? I tried moing my elev. tag a couple of time like what you have said but the elevation is not affected.
Wed, Sep 30, 2009 at 12:40:00 PM | Can't select model items by clicking
yvonnezh
I can only select by crossing window. Strange things happen when your model gets bigger and more people working on it.
Wed, Sep 30, 2009 at 12:48:44 PM | Can't select model items by clicking
mhans
3 Stars: 10 Votes
Did you say more people work on that file? Are you using worksets? Check if some items are not assigned to you.
Wed, Sep 30, 2009 at 12:52:50 PM | Can't select model items by clicking
yvonnezh
We basically just use one big workset. If certain items were not assigned to me at that moment, I at east could select them and got error if I wanted to do anything to them.
Can't select elements like in 2011
Wed, Jun 22, 2011 at 8:19:09 AM
Can't select the linked model
Mon, Aug 4, 2014 at 1:06:26 PM
Revit 2009 on Mac, How to select multiple items
Tue, Jul 13, 2010 at 11:48:42 AM
Can't select model lines
Wed, Jun 14, 2017 at 10:33:16 AM
Can't Select an object
Tue, Mar 16, 2010 at 2:06:59 PM
Page generation time: 0.8362
