Forums >> Revit Building >> Technical Support >> An error has occured while drawing the contents of this window - 2010
Mon, Sep 28, 2009 at 8:01:37 AM | An error has occured while drawing the contents of this window - 2010
RevitSVA
RevitSVA Avatar
Hi There
 I am constantly getting this message and i have installed the latest service pack
This is happening while I am working and not only when opening or closing a project
Anybody know why this would be happening??
 Please assist as I am really tired of all the problmes Revit 2010 is giving me...
Mon, Sep 28, 2009 at 8:14:19 AM | An error has occured while drawing the contents of this window - 2010
Memory ?
System?
Mon, Sep 28, 2009 at 8:35:42 AM | An error has occured while drawing the contents of this window - 2010
RevitSVA
RevitSVA Avatar
I have 4 gig Ram, Windows XP, 3gig switch is activated I have followed all Autodesk requirements
CPU 3,4 GHz, Pentium 4, Geforce 8800 GTS Graphics Card
with Revit 2009 I had no problems at all
Sat, Nov 28, 2009 at 6:47:04 AM | An error has occured while drawing the contents of this window - 2010
levvo1907
i have the same problem if you solved this problem please help me
my system is ıntel i7 920 cpu 4gb ram and zotac gtx 275 graphics,i used it almost one week and then i had this problem.
thank you
Thu, Jun 24, 2010 at 3:33:59 PM | An error has occured while drawing the contents of this window - 2010
johnsonsara
I have never had this problem until today.  My file is completely useless now.  I open it, try to make one simple change such as splitting a wall and i get the error message.  I thought maybe if the file was purged it would clean up whatever is causing this, however I am not able to purge.  I get another error message saying something about workset 1 being non editable.  This project is similar to another project we did earlier... so I copied the central file, renamed it and saved as the Central file.  I did have problems with it not saving as a central file though.  I had to resave it as central about twice a day.  I was copying a group the first time I received the "an error has occurred while drawing the contents of this window. This window shall be closed" message. I'm baffled.  I bassically cannot work in this project anymore.  I don't want to have to start from scratch.  My backup files all have the same problem.
Display error: An error has occurred while drawing the contents of this window.
Wed, Aug 24, 2011 at 6:21:14 PM
Revit 2014 - An error has occurred while drawing the contents of this window
Wed, Apr 27, 2016 at 10:27:57 AM
"error while drawing contents of this window" error. What is causing it?
Mon, Aug 25, 2008 at 5:58:47 PM
12
Error Message
Fri, Feb 18, 2011 at 2:24:25 PM
An Error Occured while Drawing this Window - This will now be Closed
Mon, May 16, 2011 at 7:23:55 AM
Page generation time: 0.7371
