Forums >> Revit Building >> Technical Support >> Problem loading components
Sun, Sep 27, 2009 at 3:55:33 PM | Problem loading components
rmln83
rmln83 Avatar
I'm having a problem loading componets. When I go to load my components, either from this website, or the ones preloaded, it never loads them. Like I go through the whole process of loading the components, and it says "regenerating" at the bottom, but nothing happens. For example, I was wanting just a simple storefront curtain wall door put in, and I went to load it from the preloaded doors, and when I do that, it automatically goes back to "single-flush" door at the top. Do I have something turned off to where it won't allow me to place components? Help!
Sun, Sep 27, 2009 at 4:55:19 PM | Problem loading components
4 Stars: 205 Votes
I think you should read first the HELP menu, it's a good "Book"....
1- select the panel
2- Unpin  the panel
3- Go to the type selector in the options bar
4- select the curtain wall door/window you pre-loaded
Sun, Sep 27, 2009 at 10:22:29 PM | Problem loading components
erland73
erland73 Avatar
4.5 Stars: 85 Votes
You don't mention what version you have or if it's happening just recently but in anyway, do yo have your Revit updated?
Mon, Sep 28, 2009 at 12:36:45 AM | Problem loading components
rmln83
rmln83 Avatar
I have Revit Architecture 2009 because I d/l 2010, but it realy wasn't much diff for what I was using it for, and I was used to 2009. No I haven't d/l the update tho, where do I get that?
Mon, Sep 28, 2009 at 3:43:40 AM | Problem loading components
4 Stars: 205 Votes
"No I haven't d/l the update tho, where do I get that?" - Go to Autodesk.com and search for the "Web Update 3" to Revit 2009...
Edited on: Mon, Sep 28, 2009 at 3:45:36 AM
problem loading components
Sun, Apr 26, 2009 at 2:21:18 PM
problems loading detail components
Mon, Jan 29, 2007 at 3:54:18 PM
Loading downloaded components into project
Wed, Aug 1, 2012 at 9:14:43 AM
error when loading components
Wed, Dec 1, 2010 at 2:33:54 PM
Revit 2019. Component, loading/finding/download family.
Fri, Mar 27, 2020 at 8:05:26 AM
Page generation time: 2.8809
