24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> What is the syntax error in this pattern
i wrote this tile pattern. when i try to load it it says "syntax error on line 3". I can't see anything wrong, can anyone help?
It's the offset (5th number) in each line that's set to 0. Each line definition is trying to draw on top of itself. Should you swop it for the number before (shift) for the horizontal definitions?
BINGO! thanks. I now see that you have to have the offsets have a non-zero x and y value so that it will behave like an infinitely repeating array that isn't just in one single line ( a zero value would make that happen, i see).
Pattern Based Panel - Rotation Error |
Tue, Feb 16, 2016 at 9:35:06 PM
Formula Syntax for PI |
Thu, Sep 13, 2012 at 6:20:34 PM
pat files |
Wed, Jul 2, 2008 at 2:49:50 PM
custom hatch pattern |
Fri, Jun 22, 2012 at 5:59:09 PM
Staggered Brick Pattern File, error |
Tue, Oct 25, 2011 at 2:12:02 PM
