Forums >> Revit Building >> Technical Support >> Phases and Elevation or Callout Marks
Sat, Sep 26, 2009 at 8:49:53 AM | Phases and Elevation or Callout Marks
SteveB
3.5 Stars: 5 Votes
It is pretty common to want to insert an elevation, section, or callout in one phase plan (for example B01-BUILDING ENVELOPE), then change the phase of the elevation, section, or callout (for example to C20-INTERIOR FINISHES) to insert other phase details you dont want to show in the referenced B01-BUILDING ENVELOPE plan.  the problem is that as soon as you change the phase of the elevation, section, or callout, the elevation, section, or callout marker disappears in the referenced plan.
Any way around that?
Callout/ Section/ Elevation marks on parallel plans
Wed, Feb 22, 2006 at 5:56:30 PM
elevation marks disappear
Fri, Jun 17, 2011 at 1:35:29 PM
Elevation Marks
Thu, Jul 24, 2008 at 6:15:27 AM
Linked Views - seeing section and elevation marks R2015
Wed, Jul 29, 2015 at 4:53:32 PM
Elevation marks Top and Bottom
Mon, Apr 20, 2015 at 4:57:40 PM
Page generation time: 1.0859
