Forums >> Revit Building >> Technical Support >> host sweep not working in R2009 when roof fascia option used on ridge and hip li
Sat, Sep 26, 2009 at 6:01:36 AM | host sweep not working in R2009 when roof fascia option used on ridge and hip li
latemore
latemore Avatar
3 Stars: 2 Votes
hi all, not been on for awhile. i used R2008 for a long time and used R2009 more recently.  but R2009 does not seem to allow the old trick of using the host sweep command in roof fascia mode to add things like ridge and hip cappings onto roof internal 'edges'. has anyone experienced this? if so have you found a work around? i am aware that we can put a mini roof over the main roof, but that is not helpful in 1:20 details. also puts extra lines on roof plan views when using wire frame and over ridden linetypes.
Sat, Sep 26, 2009 at 6:20:51 AM | host sweep not working in R2009 when roof fascia option used on ridge and hip li
4 Stars: 205 Votes
"but R2009 does not seem to allow the old trick of using the host sweep command in roof fascia mode to add things like ridge and hip cappings onto roof internal 'edges'."
Images of what you really want please, because i'm not sure what are you talking about, in 2009 you can also apply the roof fascia and the roof gutter...
By the Way, did you upgrade to the "Web Update 3" for Revit 2009?
Sat, Sep 26, 2009 at 8:50:44 AM | host sweep not working in R2009 when roof fascia option used on ridge and hip li
latemore
latemore Avatar
3 Stars: 2 Votes
well typhoon, r2009 does not allow host sweeps within a roof, only the edges.  i believe r2010 is the same.  these threads discuss it a lot.
 http://discussion.autodesk.com/forums/thread.jspa?messageID=5919838&#5919838 http://forums.augi.com/showthread.php?t=79143
most dissappointing i must say.  i will have to attempt in place families sweeps i think.
Sat, Sep 26, 2009 at 10:07:00 AM | host sweep not working in R2009 when roof fascia option used on ridge and hip li
4 Stars: 205 Votes
Weel Latemore you didn't anwser my question, maybe if you clarify the issue (by images) "We" can tell you more....
and Again: " did you upgrade to the "Web Update 3" for Revit 2009? "
How to model a Ridge & Hip Tile on the roof?
Thu, May 10, 2007 at 10:23:39 PM
2009 roof fascia
Sun, Sep 21, 2008 at 7:11:45 AM
Fascia Sweep not mitering
Tue, Aug 25, 2009 at 4:01:19 PM
12
Roof hip with different height fascia
Mon, Sep 9, 2013 at 2:25:27 PM
Partial Hip Roof
Tue, Jun 26, 2007 at 3:22:10 PM
Page generation time: 1.4227
