Forums >> Revit Building >> Technical Support >> Combining objects that are on two separate levels at the same elevation
Fri, Sep 25, 2009 at 9:20:29 AM | Combining objects that are on two separate levels at the same elevation
bfmixon
I recieved a model from a consultant that has two level 1's that are the same elevation.  They drew objects on both levels.  Is there an easy way to combine these two levels?
Thanks.
Fri, Sep 25, 2009 at 10:20:23 AM | Combining objects that are on two separate levels at the same elevation
You need to isolate the objects that are hosted on the wrong level and rehost them.  For most objecst, you should just be able to change them under their properties - constraints - and change them to the correct level.  You may have to do this piecemeal by category but you should at least be able to change them as a group.
Help Combining/merging 2 separate projects into 1
Thu, Oct 4, 2007 at 2:09:46 PM
Combining Elevation Tags?
Fri, May 18, 2018 at 9:39:23 AM
Combining internal elevation tags
Tue, Jan 11, 2011 at 4:33:22 AM
Elevation Levels Mess
Thu, Jun 26, 2008 at 11:53:13 AM
VISIBILITY OF LEVELS
Tue, Jul 13, 2010 at 12:45:49 PM
Page generation time: 3.0410
