Forums >> Revit Building >> Technical Support >> Modelling obscure shapes in Revit
Thu, Sep 24, 2009 at 7:27:59 PM | Modelling obscure shapes in Revit
Francis85
 I want to model up the below picture in Revit. In your opinion, what would be the simplest & most efficiant way of doing this. I initially tried an in-place faimly and cut out the different faces with void extrustions, but this was messy, un-accurate & time-consuming.
Any suggestions would be appreciated.
Cheers
Fri, Sep 25, 2009 at 4:51:19 AM | Modelling obscure shapes in Revit
4 Stars: 205 Votes
We can't see in Plan view but, in What version?? Well, i think i use also the "Create-in-place" Extrusions, maybe some Blend.... Only see that in plan and elevations I can decide the best way....
Sat, Sep 26, 2009 at 8:11:42 PM | Modelling obscure shapes in Revit
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
if you new all the exact dimensions, you could draw it in sketchup and load it into a family,  or you could do a conceptual mass. or try typ's idea and use some voids.
Either way you need to work out some dimensions for this first.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Revit 2009 - Grid and Level lines obscure model elements
Fri, Sep 12, 2008 at 4:00:58 AM
Logo Placement in Curve Shapes
Wed, May 2, 2012 at 9:08:20 PM
import shapes form autocad
Wed, Jan 24, 2007 at 8:50:30 AM
Topo surfaces Wont Do Concave shapes [ 1 2 ]
Sun, Dec 12, 2010 at 8:36:47 AM
19
Irregular shapes
Sun, Sep 14, 2014 at 11:58:48 AM
Page generation time: 2.2171
