20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Masking not working with detail components.
1 Posts No Rating |
I have a window mullion family with a nested rigid insulation family. I have the typical parametric dimensions.When I load the family in the central file, I cannot get the break lines to mask. It almost appears that the break line is below the detail. I have used the detail component template to create both families. I have tried to reorder the break line. I have changed the view properties to hidden line. I have tried to mask region just in case it was the break line.Out of ideas.GONE.
Hi, Check if you are in Wireframe mode. Also, can you not nest the rigid insulation?
Motto: "No Post left behind" |
masking linework behind components |
Wed, Apr 5, 2006 at 6:03:28 PM
Visibility/Graphics and Detail Components |
Wed, Feb 23, 2011 at 2:53:36 PM
Detail components in multiple views. |
Tue, Aug 18, 2009 at 2:46:35 PM
Masking Regions not "masking" |
Mon, Dec 14, 2009 at 11:21:22 PM
Detail components |
Fri, Sep 14, 2007 at 9:13:42 AM
