Forums >> Revit Building >> Technical Support >> Yet another Shared Parameter Question
Tue, Sep 22, 2009 at 1:24:34 PM | Yet another Shared Parameter Question
Hawkmoon36
I have added some parameters to a crown moulding family and for some reason, when it is loaded into the project, those parameters do not show up. They are Instance type Family Parameters. I need to have the option of adding data like material type, finish type, install date, etc. Any clues to what I did wrong?
Tue, Sep 22, 2009 at 1:27:20 PM | Yet another Shared Parameter Question
Hawkmoon36
a little more info. I also can't seem to make the parameters shared. The option is greyed out. I need to make them shared so they will show up on a schedule.
Tue, Sep 22, 2009 at 1:38:28 PM | Yet another Shared Parameter Question
You need these parameters in a shared parameter file before you create them in the family.  You can read about this in your help.
Tue, Sep 22, 2009 at 2:39:07 PM | Yet another Shared Parameter Question
lokis
It sounds like you are creating a profile family, are you creating the molding with a profile family within your project? If you are, then the parameters must be type parameters as you will not get a dialouge box for instance parameters for profiles. Also profiles cannot have shared parameters as their use dictates that any shared parameters would be useless. You can make shared parameters within a family by editing the shared parameters text file when creating your new parameter as long as the familiy is not a profile family. Hope I have answered your question.
Cannot Locate SHARED PARAMETER FILE!
Tue, Oct 7, 2008 at 3:16:48 PM
Getting Floor thickness in to shared parameter
Tue, Jun 19, 2012 at 7:30:19 AM
Shared Material Between Families
Mon, Aug 31, 2015 at 11:21:40 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
Instance Shared Parameter??
Fri, Jul 11, 2014 at 2:49:26 PM
Page generation time: 6.9710
