Forums >> Revit Building >> Technical Support >> New Elevator Family
Tue, Aug 16, 2005 at 11:48:17 AM | New Elevator Family
eyerina
Hello all... How do I create an elevator that will show up on every floor plan on which the elevator stops? I think this has something to do with the reference level of the family, the host level for the object, and the height...? Step-by-step instructions are greatly, greatly appreciated! Thanks!
Tue, Aug 16, 2005 at 1:39:33 PM | RE: New Elevator Family
Xane
You should download family from somewhere, like revitcity, insert in plan view and make hole in floor if go thru. May be you will not find elevator family for your level distance, so edit family and change height before ...
Tue, Aug 16, 2005 at 6:07:51 PM | RE: New Elevator Family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Our typical method is to use the lift doors and place on every level. These have a symbolic representation for the car built into them... Just a matter of inserting the doors on one level, copying to the clipboard and using paste by level and select all the levels you need the doors on... HTH.
Wed, Aug 17, 2005 at 4:49:46 AM | RE: New Elevator Family
Xane
Oooops, I readed eskalator. Sorry ...
Tue, Jun 22, 2010 at 9:29:09 AM | New Elevator Family
sameerahmed786
NEW PARAMETRIC ELEVATOR FROM REVIT CONTENT.COM IS VERY IMPRESSIVE, YOU CAN CREATE ANY CABIN FROM ROUNDED TO SQUARED SHAPES AND HAVE ALL THE ELEVATOR TYPES. THE ALL IN ONE FAMILY HAS A CATALOGUE FILE.....WHICH ALREADY HAS ALLOT OF OTIS PRE SET TYPES. BY FAR THE BEST FAMILY I HAVE SEEN....
ALL THE OTHE FAMILIES I HAVE PURCHASED ARE AMAZING
www.revit-content.com
Fri, Aug 26, 2011 at 8:02:39 AM | New Elevator Family
ElevatorRevit
ElevatorRevit Avatar
4.5 Stars: 2 Votes
You should download Elevatorarchitect, an elevator plug-in for Revit. The application suggests you the elevator you need and import it into your Revit project. It shows the overall depth of the car and car doors on all floors. A detailed representation of the car and doors are available on the lowest floor.
Elevatorarchitect is available as free download at http://www.digipara.com/DownloadEARevit.aspx
Mon, Oct 8, 2012 at 10:08:24 PM | New Elevator Family
polmod
thanks Mr. Spot.
yours is the best/lightest solution Smile
Mon, Oct 8, 2012 at 10:12:58 PM | New Elevator Family
polmod
and here it is
http://revit.autodesk.com/library/archive2009/html/Revit%20Architecture%202009%20Library/UK%20Library/Families/Specialty%20Equipment/Elevators%20and%20Lifts/index.html
Wed, Sep 13, 2017 at 6:42:18 AM | New Elevator Family
JessicaMadison
Essentially, I'm just hoping to make a little lift which will be private my primary base. It just requirements to help 2 or 3 persons so perhaps 4 x 2 pieces.
need help on elevator...
Fri, May 25, 2018 at 4:23:17 AM
ELEVATOR
Tue, Mar 20, 2018 at 6:51:32 AM
elevator BIM model
Fri, Sep 14, 2012 at 4:04:11 AM
Fire door in front of elevator door
Thu, Feb 3, 2011 at 1:37:28 PM
How to edit top of elevator to go up to ceiling?
Thu, Mar 10, 2022 at 7:14:22 AM
Page generation time: 1.1206
