Forums >> Revit Building >> Technical Support >> Attaching a wall to a ceiling and a roof, can it be done?
Fri, Sep 18, 2009 at 5:00:36 PM | Attaching a wall to a ceiling and a roof, can it be done?
HGL5
I have a wall that is part of a soffit, I want that wall to attach to the sloped roof and the ceiling that makes up the bottom of the soffit. I get the error that it cant be done because either the top is below the bottom of vice versa. Can this be done?
Sat, Sep 19, 2009 at 1:44:46 AM | Attaching a wall to a ceiling and a roof, can it be done?
tim123
4 Stars: 19 Votes
Check on the options bar when you click attach - there is an option for attach top or base.
Sat, Sep 19, 2009 at 10:22:10 AM | Attaching a wall to a ceiling and a roof, can it be done?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I can't quite picture this scenerio without a screen capture but either way don't forget about using the 'edit profile' option of a wall to fine tune the top, bottom or start and end of a wall.
Edited on: Sat, Sep 19, 2009 at 10:24:47 AM
Tue, Sep 22, 2009 at 3:15:43 AM | Attaching a wall to a ceiling and a roof, can it be done?
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
What do you mean by, "A wall that is part of a soffit"? i agree with dg, need a screenshot.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Wall not attaching to roof
Thu, Sep 18, 2008 at 12:58:01 AM
Problems Attaching Roof To Wall: Help Appreciated
Tue, Jun 23, 2009 at 7:09:54 PM
wall height defined by ceiling
Thu, Aug 7, 2008 at 10:21:43 AM
ATTACHING GABLE SHTG TO THE ROOF - NOT THE WALL
Fri, Dec 12, 2008 at 11:46:21 AM
Attaching a gutter to a wall instead of a roof
Tue, Feb 21, 2017 at 10:16:44 AM
Page generation time: 1.6507
