Forums >> Revit Systems >> Technical Support >> Network issue with Revit MEP 2010 error 17
Fri, Sep 18, 2009 at 8:54:18 AM | Network issue with Revit MEP 2010 error 17
ETITech
I had a problem with one on my machines obtaining a license from the Network server on 2010.  They were able to work on 2009.  The PC would connect to the server, but would not obtain a license.  Through many trials and tribulations it was discovered that if we turn off the IPv6 function and only used the IPv4 that it started to work properly.  I just thought that I would post this to see if it helps someone else.
Fri, Sep 18, 2009 at 9:44:26 AM | Network issue with Revit MEP 2010 error 17
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Thx,
I think this post should be moved to the 'Tips and Tricks' category.
Wed, Sep 30, 2009 at 12:49:41 PM | Network issue with Revit MEP 2010 error 17
JillBernhardt
5 Stars: 3 Votes
I'd recommend checking out the linked Autodesk tech doc posted on Sept. 24:  http://tinyurl.com/yawboyh
Edited on: Wed, Sep 30, 2009 at 4:31:07 PM
Jill Bernhardt
    Blog:  The BIM Bulletin
Network Deployment
Tue, Oct 9, 2007 at 8:54:23 PM
Network slowdowns using Revit?
Thu, Jul 17, 2008 at 3:16:30 PM
REVIT MEP 2010
Fri, Dec 11, 2009 at 3:09:26 PM
Licensing System error 203
Tue, Oct 19, 2010 at 9:57:58 AM
Revit MEP 2012 View Port Error with Linked views
Tue, Sep 4, 2012 at 11:50:45 AM
Page generation time: 1.5068
