22 Users Online (20 Members):
Forums >> Community >> Newbies >> Custom material Rendering Black
12 Posts No Rating |
I created a custom material today in photoshop. I created a colored tile pattern and a black and white pattern to use a the bump texture. When i try to use the colored file it renders all black. I also tried using the bump file and it worked. I can not figure out why it will not use my color file? Is there a size limit to material files? (Jpg's) If anyone can help it would be greatly appriciated.
Could you post your materials to check them?.....
Here are my materials
Try this Select the element that you want to use for the materials Copy it. open a new conceptual mass dwg. Paste it in. Under manage select object styles and then select the elements name. Then to the right click the materials properties. Then simply reapply the same process you did when first appling the materials. Good Luck.
Be brilliant,
Michael |
Custom Material Rendering black |
Thu, May 31, 2012 at 5:04:30 PM
custom material render black (i find, one anser) |
Mon, Apr 25, 2011 at 9:27:42 AM
Custom Materials Rendering Black |
Tue, Jul 13, 2010 at 5:42:22 PM
Why is my custom material rendering Black? |
Thu, Jan 14, 2010 at 8:22:35 AM
Custom Material |
Mon, Jun 29, 2009 at 10:47:47 AM
