Forums >> Revit Building >> Technical Support >> Selecting objects from a list?
Mon, Aug 15, 2005 at 12:27:56 PM | Selecting objects from a list?
eyerina
I have a pretty complicated parking garage in my building. As I create objects (general masses, walls, etc.) I name each one something very specific. Is there a command in Revit where I could select objects by name? I am thinking of something similar to Viz, where one function displays a list of the names of every object in the file, and you can highlight that name to select the object. As of now, I'm doing the hover-the-mouse-and-read-the-popup-tag method, which isn't too efficient. Thanks thanks thanks!
Mon, Aug 15, 2005 at 2:29:26 PM | RE: Selecting objects from a list?
TomDorner
4.5 Stars: 25 Votes
In the project browser go the the families section. There you will find a list of everything in the project. Go to an item name, right click and use the "select all instances". This should be what you are asking for. HTH Tom
Selecting Objects on floor below
Thu, Nov 29, 2012 at 2:54:55 PM
Selecting-De-selecting objects.
Fri, Nov 25, 2005 at 10:12:01 PM
Revit moves objects just by selecting them?????
Wed, Jul 17, 2013 at 11:53:34 AM
Move multiple detail objects at once without selecting the model beyond
Thu, Aug 13, 2015 at 5:42:07 PM
Any way to change the order of Revit Design Options in the list?
Tue, Nov 1, 2016 at 12:33:21 PM
Page generation time: 0.5689
