Forums >> Revit Building >> Technical Support >> Set Revit template so all schedules will be made with a certain fontsize
Wed, Sep 16, 2009 at 1:29:54 PM | Set Revit template so all schedules will be made with a certain fontsize
Casparos
Hi all,
each schedule i insert on the sheets i do have to change the fontsize manually,can i change the schedules / or revit template file in such a way allways have the fontsize for each newly created schedule the way i predefined?
Grtz Cee
Wed, Sep 16, 2009 at 2:06:48 PM | Set Revit template so all schedules will be made with a certain fontsize
I don't think so.  But you can setup schedules in your template.
Wed, Sep 16, 2009 at 4:49:27 PM | Set Revit template so all schedules will be made with a certain fontsize
Casparos
Hmm,
i did it with a "view" template for schedules, this works, but is a workaround.
Grtz
Revit Schedules Defined Width
Thu, Jul 23, 2015 at 12:04:40 PM
sheets pre set in template
Tue, Apr 10, 2007 at 11:36:32 AM
Large number of schedules
Mon, Jun 20, 2011 at 12:56:18 PM
Made a new family but ant rotate it properly
Mon, Jun 13, 2011 at 12:32:45 PM
Made a template file, is over 3mb
Thu, Nov 8, 2007 at 2:12:59 PM
Page generation time: 6.7148
