Forums >> General Discussion >> Revit Project Management >> direction on good workflow- split face regions and fill patterns for carpet tile
Wed, Sep 16, 2009 at 11:54:02 AM | direction on good workflow- split face regions and fill patterns for carpet tile
jheckert
Hello, my issue is in figuring out a good workflow for adding a 24"x24" carpet tile pattern to my access flooring in REVIT 2009.  I have successfully  used the split face and added a fill pattern to show individual 24" sections but here is where the issue begins.  Is there anyway to have the grid pattern show up in one view (lets say 1/8" enlarged floor plan) and have a different pattern show up for the same section at a different view (1/16" overall plan)?  Reason being is that the pattern for the individual tile reads well at 1/8" but gets confusing at 1/16".  Thanks in advance!!
Wed, Sep 16, 2009 at 11:55:38 AM | direction on good workflow- split face regions and fill patterns for carpet tile
Why not just turn it off at 1/16"?  We only show floor patterns on floor finish plan.
Wed, Sep 16, 2009 at 12:49:40 PM | direction on good workflow- split face regions and fill patterns for carpet tile
jheckert
That sounds like the right solution.  Could you please explain how you accomplish this?  Thanks!
Wed, Sep 16, 2009 at 1:02:27 PM | direction on good workflow- split face regions and fill patterns for carpet tile
VG ... model tab - floors - surface patterns - uncheck visible.
Wed, Sep 16, 2009 at 1:09:03 PM | direction on good workflow- split face regions and fill patterns for carpet tile
jheckert
Perfect... Thank you, I had a feeling it was going to be an easy fix.
Carpet Tile Hatch Pattern
Tue, Nov 9, 2010 at 9:07:17 AM
Scheduling cut and fill when using split regions
Sun, Sep 21, 2008 at 8:56:58 AM
Split face on floor?
Wed, Nov 18, 2015 at 1:16:28 PM
Fill Regions not deleting
Thu, Oct 8, 2020 at 3:52:54 PM
Model Fill Patterns
Tue, Jun 22, 2010 at 11:35:19 PM
Page generation time: 1.8484
