13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> line weights problems corresponding to ACAD ref files
Hi all, i do have problems to get the lineweights in REVITcorresponding to other drawings made in ACAD. I Don't get the lines a fine a in ACAD, is there a way to interchange, my layers including colors an lineweights from autocad into REVIT to match the lineweights. For example i created a revit "export-layers to dwg" file, with the colors and lineweights, is the import lineweights from dwg a solution? how does this ectually work? GrtzCee
You can query leayers with the autocad file and set there linetype for each one. I dont have revit in front of me but it is either within object styles or in the imported links.
J. Allen Ball Revit Architecture 2010 Certified Professional |
under file-import/export settings-import line weight dwf/dwf there the first column is the auto cad color and the second is the revit line weght
9 Posts No Rating |
I've trying this in revit MEP 2010 and its not updating the link at all.
How to match .CTB line weights with Revit |
Fri, Dec 5, 2008 at 4:11:55 PM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
Exported file to ACAD has problems with custom PATTERNS [made in acad] |
Mon, Jun 23, 2008 at 3:21:32 PM
A Nice set of Revit Line Weights |
Wed, Jun 20, 2007 at 8:47:36 PM
