Forums >> Community >> Newbies >> 2010:.....invisible walls? student here..
Tue, Sep 15, 2009 at 7:47:45 PM | 2010:.....invisible walls? student here..
blueyes
Hi all, I'm new to this forum and new to Revit. I've been working on school work and sometime from the last time I save and today I've done something to make my walls invisible when drawn. every time I draw a wall--it doesn't show. I've looked in a couple different places, I've looked in the help section but it's so big. I don't know what I did to make it so I can't see my walls. Could someone maybe explain what I did and how I can fix this? Thanks in advance
Tue, Sep 15, 2009 at 8:42:27 PM | 2010:.....invisible walls? student here..
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi blueyes, welcome here.....Ok, you have to check this: if your walls are not foundation walls or in your Visibility Graphics you didn't uncheck the walls category.....
Tue, Sep 15, 2009 at 8:47:49 PM | 2010:.....invisible walls? student here..
nafenn
Sounds like you hidden the walls by category.
Go to the visual graphics override screen (shortcut = vv)
scroll down to walls and select the box on the left.
Tue, Sep 15, 2009 at 9:42:33 PM | 2010:.....invisible walls? student here..
blueyes
Thanks, I jsut checked and the box IS checked. and I thought I would try another wall and this is the error I get..? and the walls are still invisible."None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."I really have no idea what I did...
Tue, Sep 15, 2009 at 9:44:47 PM | 2010:.....invisible walls? student here..
blueyes
also the wall is NOT a foundation wall I have selected.. it's and interior 4 7/8" partition... not sure if that helps
Tue, Sep 15, 2009 at 9:57:47 PM | 2010:.....invisible walls? student here..
blueyes
Tue, Sep 15, 2009 at 9:58:37 PM | 2010:.....invisible walls? student here..
blueyes
also, this is on the 1st floor I'm trying to add a wall, I have two floors above it--if that matters
Tue, Sep 15, 2009 at 10:16:59 PM | 2010:.....invisible walls? student here..
blueyes
Tue, Sep 15, 2009 at 11:21:03 PM | 2010:.....invisible walls? student here..
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Make sure if you didn't change its function....
Wed, Sep 16, 2009 at 3:33:12 PM | 2010:.....invisible walls? student here..
markdstonerii
Also, make sure the gase constraint is the floor you are drawing on.  For instance, if your base constraint is +6'-0", you'd be drawing the wall(s) above the 4' cut line of your floor plan.  Make sure the base offset is at 0'-0".
Wed, Sep 16, 2009 at 5:08:05 PM | 2010:.....invisible walls? student here..
#11
Hellfish13
3 Stars: 2 Votes
Also check what your view is set to-if you are using structure the default view is structure-change it to architecture or coordination. Right click anywhere on your screen go to view properties and change the discipline.
Wed, Sep 16, 2009 at 7:01:00 PM | 2010:.....invisible walls? student here..
#12
blueyes
Thanks guys! I double checked the base height and yes, it was sitting about 9 feet off the ground..I changed it back to 0 and drew another wall-and it worked. so for now..it seems to be working like it was! thanks so much for you help! Smile
student version of revit 2010
Mon, Oct 12, 2009 at 7:39:52 AM
Rendering an invisible wall.
Sun, Apr 24, 2011 at 12:01:49 PM
Columns Must Be Invisible Behind the Walls
Fri, Sep 2, 2016 at 10:43:11 AM
HELP! Revit 2016 Invisible walls and Elevators!
Tue, Dec 8, 2015 at 4:11:51 PM
Making The Invisible Visible
Thu, Aug 19, 2010 at 4:10:34 AM
Page generation time: 2.1306
