8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Layer names
208 Posts No Rating |
Hi All,
I have exported a revit drawing to dwg format and sent it to another architectural firm working in joint venture with us.
They will not accept the dwg as it does not conform to their cad layer names set-up.
Is it possible to set up my export settings table to exactly match their layer names?
cadjockey
Goto FILE... IMPORT/EXPORT SETTINGS. By default Revit Maps Categories and Subcategories to layer names and color numbers to AIA Standards. It would be nice if Revit had the option of exporting layers by linetype but it only does that for the LINES category.
Post edited on 2005-08-14 22:00:11
Hi arcodex1,
It seems to me that Revit fails to offer any real ability to export .dwg drawings with any form of competance.
From what I can see the 'cut' and 'profile' columns offer no function unless I create two separate layer to account for the same element in cut and then on profile. Our autocad 'wall' layer now needs to be 'wall-cut' and 'wall-profile' just so I can set the pen settings to export correctly.
The team of engineers and architectural firms we joint venture with from time to time are not about to change their autocad layer name protocols just because my Revit software cannot export to match their layer names.
Not impressed.
Unless I am completly not understanding how this export settings table works.
cadjockey
Cadjockey,
Go to www.augi.com and checkout the revit forums as this issue has been discussed many times...
Thanks
Exporting and layer modifiers |
Wed, Nov 16, 2011 at 4:04:33 PM
DWG export: Layer Modifier data - RVT2014 |
Fri, Nov 14, 2014 at 1:30:02 AM
Export Layer Table |
Thu, Jun 15, 2006 at 1:04:04 PM
Convert Revit to Autocad 2011 |
Sun, May 4, 2014 at 10:24:09 AM
DWG Export Mapping File - Export Family Names |
Mon, Nov 30, 2009 at 9:17:21 AM
