14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Glazing
i'm having troubles with window glazing in curtin walls. i'm trying to make them more like mirrors. i'm working with 2010. i have tryed different colors, higher reflectance, i even tried changing the glass to be a mirror. i get the same output with every try. any help would be great. thank you
Try to learn at least one new thing every day |
Go to your curtain wall and with the TAB key click several times until you select the glazing panel, go to properties> edit/new and go to materials, look at the name you have to your glazing panel, change the material by Glass, you have several glass materials, choose what you want and change (if you want) the properties of that glass.... It's a type parameter so it affect all panels with that material....
Thank you i knew that i was missing something small. i changes the properties for both types of glazing and missed the one for glass. silly me.
Curtain system > glazing panel matherial |
Mon, May 28, 2012 at 1:02:14 PM
Problem with glazing and wall alignments |
Thu, Jan 24, 2013 at 10:16:59 AM
Tell me again how to make "sloped glazing" look like metal roofing? |
Wed, Jun 11, 2008 at 9:43:34 AM
Sloped Glazing - version 2010 |
Tue, Apr 8, 2014 at 12:26:35 PM
Can't delete Glazing or System panels in Revit Structure |
Wed, Apr 17, 2013 at 9:57:51 AM
